Feature Request/Where do I look in the API?
quip
Post by quip » Fri Mar 09, 2018 3:30 am
Hello,
I'm not sure if this is a feature request, or a RTFM opportunity. Where, via the WAMP API, can I find the reported electricity usage for the day for a particular api key? If it's not int here, can we add it?
Balances with a negative value may be a good spot for it.
Thanks!
