Need help with bminer
zafar177
Post by zafar177 » Mon Mar 05, 2018 10:25 pm
Bminer -uri stratum://username.worker:password@prohashing.com:3333
Takes 15 mins to connect.when it does no shares are submitted.
spauk
Re: Need help with bminer
Post by spauk » Tue Mar 06, 2018 11:41 pm
i haven't tried bminer yet, but the port is 3333, and you need a=equihash in the pw. i've been trying to run ewbf on prohashing every once in a while to test it but i don't even know if equihash is fully enabled yet. i always get a wrong algorithm message
zafar177
Post by zafar177 » Tue Mar 06, 2018 11:59 pm
Woops edited the post to show correct port 3333
zafar177
Post by zafar177 » Thu Mar 08, 2018 5:50 am
Couldn't get bminer to function properly, it connected but failed to process any shares..
Switched back to ewbf which connected and accepted shares.
Post by Steve Sokolowski » Thu Mar 08, 2018 8:05 am
spauk wrote:i haven't tried bminer yet, but the port is 3333, and you need a=equihash in the pw. i've been trying to run ewbf on prohashing every once in a while to test it but i don't even know if equihash is fully enabled yet. i always get a wrong algorithm message
Equihash is fully enabled now, so you should be able to run with it. We haven't had any reports of any issues since last night, so I think the previous problems have been resolved, and we plan to continue running equihash indefinitely.
