A question about how to change to solo
I'm a Antminer L3+ user, my English is not good. i have a problem, how to transfer from pps to solo, can you teach me? Thank you !
Re: A question about how to change to solo
the first thing you need to do is make sure you have an address saved for the coin you want to solo mine. then add c=coin m=solo to your password arguments and include quotations around it if it doesn't accept more than one pw argument (change the coin name to the name of the coin you want to mine). there is no transfer between pps and solo mined because it is whatever you had your miners set to do at the time, and prohashing doesn't exchange coins after they are earned.
here's an example password for verge solo mining: "a=scrypt c=verge m=solo n=L3+"
and it will only work properly if you have a verge address saved in settings and the coin name spelled correctly after c= (as it appears on the site)
i'm sure you can find all of this information on the help page if you can translate it
Thank you very much !spauk wrote:the first thing you need to do is make sure you have an address saved for the coin you want to solo mine. then add c=coin m=solo to your password arguments and include quotations around it if it doesn't accept more than one pw argument (change the coin name to the name of the coin you want to mine). there is no transfer between pps and solo mined because it is whatever you had your miners set to do at the time, and prohashing doesn't exchange coins after they are earned.
