Two small questions.
Are the 'Total Earnings' before the Pool fee? And which exchange do you use to buy the coins for a payout? (I'm interested to view the exchange rate that you use, as this affects the number of coins I get).
Live balances - I switched to 100% payout of Gulden months ago. I've noticed that every now and then, my Litecoin balance creeps up (just a tiny amount). So, a couple of days ago, the balance was 0.0044. It's now 0.0068. This isn't a problem, I'm just curious as to why my Litecoin balance edges up, even though my account is set for 100% payout to Gulden.
Thanks
Ian
Total Earnings and Live Balances
Re: Total Earnings and Live Balances
I do know that the exchanges used are listed under each coin if you click on them on the Charts tab, all the way at the bottom at Live Coin status. It shows the exchange rate for each coin and the exchange used. Not sure about your other questions
I also believe the pool software pics the highest exchange sell price (of all the Xchanges listed) to ensure highest profit. At least thats the way it appears to me as it runs
@Jack - Thanks for the info. I'll check the charts tab.
Regards
Ian
Regards
Ian
