- We're pleased to announce that we have filled the position for a trading engine developer! While we aren't able to announce his name until after he resigns, he will be starting in April. That means that customers can expect to see a lot of new exchanges and coins being added as early as May!
- Speaking of coins, Chris has been adding SHA-256 and equihash coins in preparation for the rollout of mining of those algorithms. As many as 10 new SHA-256 coins are becoming available for payout every day as this process continues. Feel free to check these out and add these for payout if you would like.
- The issue with the worker count being incorrect revealed a number of misconfigured miners that were constantly reconnecting to the mining server after their password arguments were invalid. Some of these miners reconnected over 100,000 times per day. The issue does not affect the mining server because the miners simply fail to authenticate, but these miners often trigger the ban code and if you can't connect, you might want to check your logs to see whether you mistyped something and your mining software is faulty and reconnects repeatedly.
- Constance will be rolling out her new polling feature over the coming days. Our first polls will ask customers which features they feel are the highest priority.
Status as of Wednesday, February 14, 2018
Good morning!
Re: Status as of Wednesday, February 14, 2018
correct me if im wrong but wasnt the second of the two new algos supposed to be for ethereum? equihash isnt eth's algo, ethash is. im probably just being dumb and misread ethereum from the beginning..
Yep, it was, but Ethereum is completely different from the other algorithms because of the concept of "uncle blocks" and the way its mining protocol is implemented.GregoryGHarding wrote:correct me if im wrong but wasnt the second of the two new algos supposed to be for ethereum? equihash isnt eth's algo, ethash is. im probably just being dumb and misread ethereum from the beginning..
ZEC only took two weeks to get in. The other reason we chose ZEC is because the open source code on the Internet is buggy or has security vulnerabilities, and because of what I found any pool that is running the open source software will be making less profit than we are even before the other things we do differently.
thanks for the clarification, i dont recall reading a post explaining the switch from eth to zec so that explains my confusion.
