Leafcoin active?
shtrudel
Leafcoin active?
Post by shtrudel » Fri Feb 09, 2018 10:12 pm
Hello,
All the numbers in the leafcoin are 0. I added it to my account, but nothing shows up for leafcoin.
Is leafcoin active?
Thanks,
Shtrudel
Re: Leafcoin active?
Post by GregoryGHarding » Fri Feb 09, 2018 10:24 pm
"All exchanges for this coin have at least one error."
theres also an exclamation point on the coin, meaning its in error, it cant be mined at this time
shtrudel
Post by shtrudel » Fri Feb 09, 2018 10:34 pm
Thank you sir!
Where do you see the exclamation point?
shtrudel
Post by shtrudel » Fri Feb 09, 2018 10:35 pm
Another question, what happened to the 10% mining allocation I had for the past 24 hours?
Post by GregoryGHarding » Fri Feb 09, 2018 11:15 pm
shtrudel wrote:Thank you sir!
shown on the home page under coin stats
shtrudel wrote:Another question, what happened to the 10% mining allocation I had for the past 24 hours?
no idea what youre referring to
spauk
Post by spauk » Sat Feb 10, 2018 10:33 am
if the coin daemon is working i think you can still solo mine most coins even if there are no exchanges, but i don't know if you can solo mine merge mined coins. if you had 10% leafcoin as payout and it's not available on any exchanges, that 10% is divided into the other payout coins selected.
shtrudel
Post by shtrudel » Sat Feb 10, 2018 1:19 pm
Thank you. Appreciate!
Post by Steve Sokolowski » Mon Feb 12, 2018 8:42 am
spauk wrote:if the coin daemon is working i think you can still solo mine most coins even if there are no exchanges, but i don't know if you can solo mine merge mined coins. if you had 10% leafcoin as payout and it's not available on any exchanges, that 10% is divided into the other payout coins selected.
You can't solo mine merge-mined coins. While there's nothing theoretically preventing anyone from doing that, we added a check to prohibit the feature because it doesn't make sense economically. Merge-mined coins are generally only 1% as profitable as any other coin, and there's no reason not to mine a different coin and earn the merge-mined coins as a bonus.
