Error submitting block at height 141295 from here-goes-wallet-address@127.0.0.1, share type: "trusted" - {"code":-7,"message":"Block not accepted"}
Transaction not found in pool
at the same time. We lose ~50% of mined blocks with such errors. The question is, what is the normal rate for such errors? Is 50% indeed normal and what we can do is just to give up and live with it, or there is a room for improvement?
