Hi there. I have been mining at FOUR different pools, and I would love to merge them all into Prohashing.
I have various CPU and GPU (NVIDIA and ATI) machines, and two ASIC miners, all under Linux.
For example, I have a Centos 7 machine with Claymore with RX580 card. Only claymore can find the card; bfgminer simply ignores it as do other software that I tried. However, the same bfgminer finds the NVIDIA card of another machine and works fine with it.
One thing they have in common is that neither can work with prohashing currently. The work I submit is ignored and the "earnings" page always shows zero accepted work. So, I'm at a loss at how to merge all these devices into THIS pool..
Any *pointers would be appreciated.
-t
Cannot find a way to switch to prohashing
Re: Cannot find a way to switch to prohashing
As a test, point them all to mining rig rentals so they all show up as 1 rig, and then control where the rig setup goes.
Although, if I had GPU rigs I would be looking for some ether or some other asic-resistant coins to mine with those to maximize my profits.
