If you select Smileycoin as your payment coin of choice, it won't work. Instead the proceeds go to LTC instead.
Anyone has this issue ?
Smileycoin payments not working
cryptouser
Re: Smileycoin payments not working
Interesting.
Which miners do you have and what password settings are you using?
if you look at the coin on live coin status it needs to be working properly there. i see all exchanges for this coin are in error. litecoin is like the default payout coin if the coin is in error. you could solo mine it and get payout though probably, if you can solve blocks
