All,
I'm having issues with L3+ miners difficulty argument. When I set the static d= in pw field, miners disconnect & rollover to backup server.
Here are the current pw arguments:
n=ASIC1 p=0.10 w=800 m=solo c=Litecoin d=262144
Without the diff argument, the miners connect for a while (between 1hr-5hrs) then rollover to my default backup server. Any ideas as to what I am doing incorrectly?
Thanks in advance for the help!
L3+ Solo - Setting Static Difficulty Disconnects
- Contact:
Owner | CryptoCoin, LLC |
- Contact:
Re: L3+ Solo - Setting Static Difficulty Disconnects
I've been doing a bit more testing..decided to try using the proxy URL. When using stratum+tcp://proxy.prohashing.com:443, setting the static difficulty works properly.
EDIT: After about a half hour of mining the miner disconnects with server dead and rolls over to backup server still.
