Solo Mining Setup Issue - Antminer L3+
scorpiomaj27
Post by scorpiomaj27 » Thu Jan 11, 2018 11:02 am
Hello folks,
First time poster, so might be a stupid question, but I've got my L3+ setup with the following:
http://prohashing.com:3333/ c=bitcoin m=solo
The Antminer shows this pool as Alive. However the Live Worker Status on PH says Mode: Pay-per-share, am I doing something wrong?
Thanks!
-Jason
PS. Also, I cannot Forfeit my $0.02 of Bitcoin - I'd just like it gone, must be too little to even forfeit.
FastCashMining
Re: Solo Mining Setup Issue - Antminer L3+
Post by FastCashMining » Thu Jan 11, 2018 11:36 am
Don't believe you can mine bitcoin on PH.
FastCashMining
Post by FastCashMining » Thu Jan 11, 2018 11:37 am
It is also an L3+, a scrypt base algo miner, not a SHA-256 miner (which is bitcoin algo).
scorpiomaj27
Post by scorpiomaj27 » Thu Jan 11, 2018 11:39 am
That's per the instructions on the help page, says if you enter Bitcoin for a scrypt miner it will automatically switch.
Post by AppleMiner » Thu Jan 11, 2018 12:26 pm
Those are the error settings for a scrypt miner which will result in it doing something else.
If you would like to solo litecoin for example coin for a password use: m=solo c=litecoin
If you would like to mine all the best coins and take the payout in the coin you would like to specify in the settings pages: no password at all.
Welcome to the pool.
HAPPY HASHING!
scorpiomaj27
Post by scorpiomaj27 » Thu Jan 11, 2018 1:51 pm
AppleMiner wrote:Those are the error settings for a scrypt miner which will result in it doing something else.
HAPPY HASHING!
That seems to have done the trick, thanks!
