No password aguements
and i get this
according to your stats
"live worker status"
Since first share: 06:18:55
and the miner says similar its self,no getworks from other pools or anything else,all work form prohashing
not only is it not reporting all the blocks/shares i summit its reporting completely wrong info?...............or if that info is correct *that my miner did summit something of the wrong algo* why is your end sending bad workunits out and then penalizing me for it?
Now why after 6 hours am i finding things like this
