- A lot of support tickets came in, this time with different "live worker status" issues. I'm going to spend one more day trying to resolve the problems, and if I'm not successful one more time, we'll pull the feature until we can get back to it later in January.
- I resolved the issues with the "1 MH/s expected payouts" chart. It turns out that no modifications were needed to the formula, as I had thought would be. Instead, the issue was that we were using the litecoin data from yesterday and multiplying it by the prices from today. Since we are on the downside of a bubble now, every day's profitability for the past few weeks has been too low because incorrect pricing data was used. I corrected it starting yesterday, and you can now see that the chart shows that we were equal to LTC. Since there was downtime yesterday for the "live worker status" upgrades, and the downtime is included in the calculation, that means that the payout rate was higher than LTC, as should be expected.
Status as of Friday, December 29, 2017
Good morning!
Re: Status as of Friday, December 29, 2017
Good afternoon
I see it was a "live worker status" issue now because the miner efficiency was working good.
Thank you for adressing this
Kind Regards
Greatings from Amsterdam
Kind Regards
This has cost prohashing quite a lot of money i think, i pulled 17 asics off and moved them to nicehash because i wasnt sure if I was earning the correct amount. I'm moving them back though now !
PS after the nicehash hack I am sticking with prohashing all the way. I do not trust nicehash anymore unless they refund me my bitcoin owed.
I discovered a potential problem with the "live worker status" display. It seems that some miners reauthorize themselves, resulting in duplicate records that cause problems. I made a modification to delete the duplicate records and replace them with the most recent authorization, and we'll see how that works later today when it is released.
current L3+ scrypt earnings info.
50 hours ago I've moved one of my 504Mh L3+ to litecoinpool.org. And my earning are:
PH: 0.12864063
litecoinpool.org: 0.150640062
about 15%. Hmm...
Yes, both are located in different locations(different ISP, temperature, etc).
I'd left PH mid of November. Came back to test current PH performance. I've expected something similar to whattomine or even better.
Any ideas?
PH: 0.12864063
about 15%. Hmm...
Any ideas?
That seems unusual. After I corrected the error in pricing, you can see that yesterday's profits should have been exactly equal to LTC. It's possible that your miners don't perform well with frequent work restarts, but some customers have also had a better experience by setting manual difficulty with L3s.coldlexm wrote:current L3+ scrypt earnings info.
PH: 0.12864063
about 15%. Hmm...
Any ideas?
AppleMiner can probably help you better than I can with finding out the best settings for your particular miners.
I could also use the help then since I have not gotten better than 0.09Steve Sokolowski wrote:That seems unusual. After I corrected the error in pricing, you can see that yesterday's profits should have been exactly equal to LTC. It's possible that your miners don't perform well with frequent work restarts, but some customers have also had a better experience by setting manual difficulty with L3s.coldlexm wrote:current L3+ scrypt earnings info.
PH: 0.12864063
about 15%. Hmm...
Any ideas?
Id love some help on password rules of difficulty, restarts or what not if there is benefit to be had.
OK. Thank you!.Steve Sokolowski wrote:That seems unusual. After I corrected the error in pricing, you can see that yesterday's profits should have been exactly equal to LTC. It's possible that your miners don't perform well with frequent work restarts, but some customers have also had a better experience by setting manual difficulty with L3s.coldlexm wrote:current L3+ scrypt earnings info.
PH: 0.12864063
about 15%. Hmm...
Any ideas?
First I'll try to switch both miners between PH and litecoinpool and check earnings.
