Hi.
So I seem to have a small problem with prohashing and my l3+ doesent seem to register my last shares.
logged onto the miner and it hasent changed pool because ive got no shares accepted elsewhere other than Prohasing.
here are some stats from the last 6 hours from the miner on prohasing.
getworks 1,166, accepted: 710, rejected: 16 elapsed time: 6h23m40s
So directly on the miner it seems to be working, but not on the homepage.
last accepted share by prohashing webpage is: 06:38:14
Thats 6 hours ago.
I dont use any password phrases
and ive added stratum + #xnsub in url.
this is not the first time and it seems like i get disconneted a couple of hours during the day
whats the problem here?
have no disconnection problems with for example litecoinpool.
shares not registering
Re: shares not registering
#xnsub in url is NOT needed.
If the pool says it hasnt processed shares in a while it is likely busy doing the daily payout cycle.
Once that is tabulated then the rest of the shares are injected, no work is lost, you should get credit for all the work you did in the meantime.
They log the shares, so even if there is a server reset, they just back out the shares they had read in, and re-read the whole log sheet back in so all the miners get their credits.
