Is there any reason that Two-Factor Codes are not being sent?
I am not logged in the system and am not receiving sms two-factor code. How can I log in?
Finally!!!
Login Issue: Two-Factor Codes Not Sent
Re: Login Issue: Two-Factor Codes Not Sent
try logging out of your account then log back in and once loaded try setting up 2fa again sometimes it takes a couple minutes for the barcode/key to generate.
