Profit Comparison 12/17/17-12/23/17
Scrypt Pool Comparison - Two L3+
Sunday
P2P- no blocks, PP 0.04854772 LTC
Prohashing- $58.75
LTC Pool- 24 hours 0.19358136 LTC = $61.32 USD as of 12:03am
Monday
P2P- 1 block @ 0.08520656 LTC = 32.01 USD as of 12:08am
Prohashing- $55.52
LTC Pool- 24 hours 0.18132340 LTC = $68.12 USD as of 12:08am
Tuesday
P2P- 1 block @ 0.09892221 LTC = 33.52 USD as of 12:05am
Prohashing- $57.16
LTC Pool- 24 hours 0.17600160 LTC = $59.64 USD as of 12:05am
Sunday
Prohashing- $58.75
Monday
Prohashing- $55.52
Tuesday
Prohashing- $57.16
Re: Profit Comparison 12/17/17-12/23/17
Which ltc pool are you using?
Did you rotate the settings across the test pairs to verify the settings vs the miners?
its random luck.. if your mining solo
would have to know the settings you used at each pool to compare.
were the payouts all in the same coins or converted?
cvmines2 wrote:Scrypt Pool Comparison - Two L3+
Sunday
Prohashing- $58.75
Monday
Prohashing- $55.52
Tuesday
Prohashing- $57.16
So why exactly are you showing us information without giving the full information?
You're giving us prohashing $ value which may not represent the same $ value from your LTC pool depending on what exchange/time they took it
The only important information here is not the $ value, it's the LTC amount.
For instance, if i wanted to, because of the variance of when the $ amount was converted, i could say your entire post looks like this.
Sunday
Prohashing- 24 hours 0.19358136 LTC = $58.75
Monday
Prohashing- 24 hours 0.18132340 LTC = $55.52
Tuesday
Prohashing- 24 hours 0.17600160 LTC = $57.16
Which would obviously show the same exact amount of LTC mined at prohashing as well as at LTC pool. But that's probably not correct right? But, you haven't given us the actual IMPORTANT information that makes any of these "tests" relevant.
And before you, or someone says "Well Prohashing doesn't tell you how much coins you got, it just says the $ amount"----- Incorrect, hover over the $ amount and it'll show you how much LTC you made.
