I have an antminerl3+ Suddenly mining efficiency falls to zero. Miner status screen shows normal. I am seeing the following in my kernel log.
Dec 19 16:57:09 (none) local0.notice cgminer[382]: Dump IIC Data:[1][98][0][18]@ChainID:[0], Chip[C]
Dec 19 16:57:09 (none) local0.notice cgminer[382]: Dump IIC Data:[1][98][0][16]@ChainID:[1], Chip[C]
Dec 19 16:57:09 (none) local0.notice cgminer[382]: Dump IIC Data:[1][98][0][18]@ChainID:[2], Chip[C]
Dec 19 16:57:09 (none) local0.notice cgminer[382]: Dump IIC Data:[1][98][0][17]@ChainID:[3], Chip[C]
Mining efficiency zero
Re: Mining efficiency zero
Have you flashed the firmware before? I'm trying to read up on this and all i can find is that people flashed their L3+ incorrectly, for instance, once guy accidenly flashed his L3+ with D3 firmwarekenthead wrote:I have an antminerl3+ Suddenly mining efficiency falls to zero. Miner status screen shows normal. I am seeing the following in my kernel log.
Do any of the hashboards show up (or are any missing) when you access your miner?
Should show 4, just like above.
Mining efficeincy takes 2 hours to get a good reading.
I think they rebooted the server.
Until its hit a 2 hour mark that reading will likely be off for a while.
FYI...it is normal for you to have 0 mining efficiency when the pool isn't up for you to connect to and mine on.
