L3+ Wont connect aigan.
I was messing with my L3+, I accidently entered a=x11 in my password, wich is the wrong algorithm for my l3+
Prohash said the miner is mining the wrong algorithm. I deleted the password.
Miner didnt do anything, rebooted, still didnt do anything. Even a reset didnt do anything.
I can mine on other pools without any problem, but since I set a=x11 and deleted it after 10 minutes, prohash just wont work at ALL.
It seems it wont connect, "socket connection failed" - ONLY on prohash.
The pool is dead to me since I did that.
Any solutions?
Thanks
Any solutions?
Thanks
IzzyMoreno
Re: L3+ Wont connect aigan.
Try maybe to force scrypt with a=scrypt
IzzyMoreno wrote:Try maybe to force scrypt with a=scrypt
Good suggestion, weird I didnt think of doing that.
But, didnt help, still dead :/
have to give it time, and sometimes a LOT of time.
AppleMiner wrote:have to give it time, and sometimes a LOT of time.
You think there is no issue?
Its my guess cause it happened after the wrong algorithm change.
Steve told me they removed the limits, so apparently means if the settings are right they should instantly reconnect.
Rename the miner, reboot your router/modem.
put n=miner1 for the password and try that.
The miner is in a datacenter,that should be no issue.AppleMiner wrote:Steve told me they removed the limits, so apparently means if the settings are right they should instantly reconnect.
Naming the miner didnt work either :/.
So far I did: Rebooting/ Resetting / Proxy pool / a=scrypt forcing / Renaming
Other pools keep working fine btw.
Update; Rebooted aigan, switched to another worker named "testaccount" I saw this in another topic, still dead.Twinkie wrote:The miner is in a datacenter,that should be no issue.AppleMiner wrote:Steve told me they removed the limits, so apparently means if the settings are right they should instantly reconnect.
Nothing helped, Im kind of losing my patience, what the hell could it be... Its like prohash doesnt even exist for the L3+.
Was there a solution for this issue? I suspect I have the same problem as to why the L3+ won't connect.
Tried suggestions above, not sure if it is a timing issue or what else needs to be done.
Same issue here. Ive tried just about everything I can find on my own. Its like my particular miners are locked out of the pool.
