L3+ Solo EMC2
L3+ Solo EMC2
Please help me set up solo on L3 +.
Wallet EMC2 added to settings account.
c=einsteinium m=solo n=1
result
stratum+tcp://prohashing.com:3333 Poling Dead 19 0 0 0 0 0 0 0 0 0 0 Never
result
Re: L3+ Solo EMC2
wait 20-30 mins, check again.
There is a max worker limit, it will take some time after applying the settings before your miner will get a spot from someone else rebooting or logging off and your miner gets their slot.
Re: L3+ Solo EMC2
That max worker limit was removed, and it is no longer active.AppleMiner wrote:wait 20-30 mins, check again.
If there's any connectivity problem after this, they are caused by something else.
Re: L3+ Solo EMC2
Steve can you confirm that Prohashing is mining EMC2 on the correct chain? I am mining a=scrypt with 100% EMC2 payout. Payouts are going to Bittrex which has updated their wallet and the funds are still confirming. Just want to make sure. Thanks for your help....
Re: L3+ Solo EMC2
Is einsteinium solo mined only?Steve Sokolowski wrote:That max worker limit was removed, and it is no longer active.AppleMiner wrote:wait 20-30 mins, check again.
Re: L3+ Solo EMC2
This is an issue that you should submit a support ticket about, so that it can be handled by the person best qualified for the issue. In this case, Chris would be assigned the ticket, so if you are still having a problem, I recommend going to https://support.prohashing.com/.iamjaypee2 wrote:Steve can you confirm that Prohashing is mining EMC2 on the correct chain? I am mining a=scrypt with 100% EMC2 payout. Payouts are going to Bittrex which has updated their wallet and the funds are still confirming. Just want to make sure. Thanks for your help....
Re: L3+ Solo EMC2
When you check on Prohashing.com -> Charts -> Live coin status, you will see a red bar around "Einsteinium" and the message: 'All algorithms for this coin are in error.' which means it is unavailable for mining via Prohashing at the moment. On top of that I recall Steve saying once that there is some issue with solo mining EMC2 due to charity blocks or so.Poling wrote:Please help me set up solo on L3 +.
result
Re: L3+ Solo EMC2
Last time I sent EMC2 to Bittrex it needed 120 confirmations, which took quite some time. What number is shown next to your 'pending' balance?iamjaypee2 wrote:Steve can you confirm that Prohashing is mining EMC2 on the correct chain? I am mining a=scrypt with 100% EMC2 payout. Payouts are going to Bittrex which has updated their wallet and the funds are still confirming. Just want to make sure. Thanks for your help....
