Android Status
zalitso
Android Status
Post by zalitso » Tue Dec 12, 2017 7:34 am
I have been unable to find any Android apps that can pull the statistics from Prohashing. Is anyone aware of one?
Thanks in advance.
doomguard
Re: Android Status
Post by doomguard » Tue Dec 12, 2017 10:08 am
Would like to know this too. Need PH link to api to extract data.
Re: Android Status
Post by AppleMiner » Tue Dec 12, 2017 2:57 pm
example someone posted some time ago.
Use at own risk!
https://pas.ma/prohash/
