I had to go back to mining at another x11 pool. This is the 3rd time this week that I awoken to dead pool status and struggled for over and hour to still not be able to get a response from the pool.
Also the website has not been functioning well. Half the time it doesn't respond and times out or if I am able to get the site to load and login, the mining data doesn't load.
Frustrating to say the least. I've as of yet to be able to connect to the pool this afternoon. Connects to antpool just fine, however I don't really want to mine at antpool but doesn't seem to be much of a choice. Other x11 multipools seem to be having issues as well.
Same with the forum, sometimes the forum loads, other times it times out just like the prohashing.com site.
just an FYI. I've been mining on and off at prohashing for a couple of years and am not sure whats going on. Seems to be a lack of consistancy with whatever host or server you are using. Took me over 5 tries hitting submit to get this to post.
Edit.. Maybe get a backup server so there is more than one option for ports to connect to? IDK what the solution is but this isn't working. Just burning time and money.
3rd time this week x11 port 'dead'
Re: 3rd time this week x11 port 'dead'
Got a connection again now. Wouldn't connect for past 2 hours (or longer, not sure due to being asleep) but seems ok now. Set up another failover at antpool just in case both multipools I use go down at same time again.
The servers were down some today for a restart and I think there was some issues getting the restart up and running correctly.
Did you log into the chat and check what the topic people were chatting about was?
Or ask in there for help or login to see if the top of the page had any live stats?
usually when no live stats are up the pool might just be down.
It's been down for days, i had to switch to a dash PPLNS pool =/
