NewYorkcoin payments
MrCoffee
Post by MrCoffee » Mon Dec 11, 2017 5:31 am
I mined for about 25$ Newyorkcoin. But since 2 days I got no payment. Do I need special wallet adress or must I add coin in settings or what do I have to do?
Thanks in advance
Re: NewYorkcoin payments
Post by AppleMiner » Mon Dec 11, 2017 5:37 am
Can you list your settings you have in your miner that you are using.
URL:
username should be your username on prohashing.com
password:
and what type of miner you are using.
What coin you have selected as your payout coin in the settings, and what the slider percent is on.
MrCoffee
Post by MrCoffee » Mon Dec 11, 2017 6:15 am
I am having L3+ Miner. I am using correct username, Coin to payout is Litecoin
While mining Newyorkcoin I used password n= holland m=solo c=NewYorkcoin
After getting no payment I changed password to n= holland
I am having second L3+ miner with standard password and same username, the Litecoinpayment is working fine.
Camey
Post by Camey » Mon Dec 11, 2017 6:44 am
When you solo mine you will only get paid out in the coin you have mined, so you need to ensure you have loaded a wallet address for that coin on Prohashing
MrCoffee
Post by MrCoffee » Mon Dec 11, 2017 8:31 am
Thanks
