Payout per worker
Payout per worker
Is there away to determine what each worker is earning? I can only see the combined payouts. Any advise?
Re: Payout per worker
Divide by your hashrates. If different algorithms, (x11 vs scrypt), use the "1 MH/s expected payouts" for at least one of them, calculate that (for instance, if you had 504MH for Scrypt yesterday, that'd be 504x0.0289 to figure out what the your miner should have made (won't be 100% accurate). Then take whats left for your x11 earnings.
Though why people are so fixated on a number that'll give them meaningless information is beyond me. The only reason to want to know this information is to try and see if you're spending more in electricity then getting back in revenue, and there are far better services to do that since you're going to have to do the math (your electricity rate x wattage etc.) at such places like whattomine
Thanks Aura89. I will give that a try. Just curious I guess.
