Is it possible to change payout percentages?
I'm in https://prohashing.com/settings.html
But i can't seem to adjust payout percentages? Did I miss something?
Re: Is it possible to change payout percentages?
If you only have 1 coin there wont be anything else to choose from.
You will need to add a 2nd coin and move the slider up and click SAVE.
then down below add a wallet address in for that new coin and SAVE down there.
Then you can use the slider to decide how much each coin percentage is set to.
Additionally, if you are accessing from a phone you'll find it very difficult (if not impossible) to move the sliders. Best from a PC.
Would be nice if the system let us type in the % rather than only being able to do this via sliders.
I am also having issues with the slider. I can not unlock the proportion or delete a added coin either.
This is something that Constance is going to look into right away.nemesis-t-warlock wrote:Would be nice if the system let us type in the % rather than only being able to do this via sliders.
jluyt123 wrote:I am also having issues with the slider. I can not unlock the proportion or delete a added coin either.
That! I can't seem to change the slider despite having 2 coin type payouts.
