Errors with Difficulty in server
greaseman316
Post by greaseman316 » Mon Dec 04, 2017 11:36 pm
Came home to find all miners freakin out and stuck on PH. played a bit rebooting my machines and noticed when set on dynamic the difficulty was crazy numbers. reset miners with this problem to a static difficulty of 64 and have gotten all back online. the 1 miner that was still connected and actually working i have been watching the difficulty ranging from 64 to 1.96k it is all over the place.
Couple of the miners before reset was stuck at 65995 difficulty. once reset would return to this difficulty.
hope thats enough info to point you in right direction
thanks G
Sorry forgot to add i have D3s
greaseman316
Re: Errors with Difficulty in server
Post by greaseman316 » Tue Dec 05, 2017 1:56 am
Quick update been playing last hour and a half. When i remove the d setting miners start at 65536.00 and hangs there an does nothing. wont kick over to backup pool just hangs out.
Will remove the d setting as soon as you let us know everything is back to normal.
Post by Steve Sokolowski » Tue Dec 05, 2017 7:34 am
Thanks for the report. I'll investigate the issue and provide an update later.
