Hello fellow miners,
I have a problem with my Bitcoin Core wallet and am willing to pay someone a commission if they can provide the solution. My wallet seems to be stuck on a transaction and I cannot find a way around it. When I try to send a payment it processes fine and I even get the popup that says I have sent it. However, when I go to the transaction tab and click on the transaction it says the status is "0/unconfirmed, not in memory pool". I googled this issue and found plenty of material about "0/unconfirmed, in memory pool" but not much on the subject when it is not in the memory pool. The wallet is synced and otherwise operates fine.
Below is an example of my transaction summary:
Status: 0/unconfirmed, not in memory pool
Date: 12/1/2017 14:35
To: Transfer xxxxxxxxxxxx
Debit: -0.41103270 BTC
Transaction fee: -0.00106257 BTC
Net amount: -0.42209527 BTC
Transaction ID: 155f742b0d33e86fd714a761d40de163c4ebd1788c017732db932467f79cfa92
Transaction total size: 6389 bytes
Output index: 0
Bitcoin Core version v 0.15.1
Michael
BOUNTY OFFERED FOR FIX
Re: BOUNTY OFFERED FOR FIX
Which version of the Bitcoin Core wallet are you using ?RCMco wrote:Hello fellow miners,
Output index: 0
Michael
I should have posted that.... It is 15.1
Your wallet is viewing it as an invalid transaction, did you pick inputs manually? As to how to fix it.. no real idea, maybe resend with different inputs? but you might have to zap the wallet to make it forget the invalid transaction.
i had the same kind of issue with jaxx, i had to reset the jaxx cache and all was good
