Solo mining only, calculating hashrate
jaether
Post by jaether » Tue Nov 28, 2017 4:26 pm
Hi there,
I have a question about solo mining BitConnectcoin. About 3 weeks ago (Before the problems started with the pool) I was solo mining BItconect.
I could see the hashrate of my miners and i saw the shares. When the problems occurred the miners stopped showing the hashrate, the only thing
that was showing is "calculating hashrate' or 'no valid shares'. also the connection went constantly dead.
I thought that after yesterday the problems were fixed and solo mining would also be stable again. But unfortunately the same inconsistency is happening. miners don't show hasrate, only 'calculating hashrate..." or "No Valid shares'. Can somebody explain what is going on. Am I really solo mining? and why I don't see the hash rates? and last but not least why the connection is lost every now and than? Is this problem only with Bitconnect solo mining or other coins have the same problem with solo mining.
Please explain thiis
Re: Solo mining only, calculating hashrate
Post by AppleMiner » Tue Nov 28, 2017 4:28 pm
Can you please post the password setting the miner is using to connect to the pool.
jaether
Post by jaether » Tue Nov 28, 2017 4:35 pm
n=jupiter01 m=solo c=Bitconnectcoin
jaether
Post by jaether » Tue Nov 28, 2017 5:10 pm
I have more L3+ miners with same settings, of course different names.
