is there a way to list or print up total earnings from prohashing
sirslayerjr
Post by sirslayerjr » Sun Nov 19, 2017 11:07 pm
is there a way to list or print up total earnings from prohashing ??
whinerminer
Re: is there a way to list or print up total earnings from prohashing
Post by whinerminer » Tue Dec 26, 2017 2:20 pm
<bump>
I'd like to know if there is a way to do this as well in the future. Makes it easier than tallying each day's totals manually.
Thanks!
investmentgroup
Post by investmentgroup » Tue Dec 26, 2017 4:49 pm
Not exactly the answer to the question, but I'm able to gather this data from the tax reporting software I use, bitcoin.tax. I mine into specific wallets that only receive inputs from mining activity. Then I add the addresses in the Income tab on the site and it will scrap earnings off the block chain. I am currently using BTC, LTC, DASH, and BCH addresses. Not sure what if any other addresses they support. You can also download the data in CSV format if you want to do some of your own crunching on it later. Like I said, doesn't really answer how to get the data off ProHashing, but thought I'd share how I report on income in case it's helpful.
henriu3
Post by henriu3 » Tue Dec 26, 2017 7:42 pm
I have google sheet scrypt that some guy Gave to me. With that scrypt you can look at the total
Mined coins to n USd
