How high is my share in this Pool by PPS when I found the following block, for example?
Coin: Litecoin
Fees: 0.0002297
Value: $1,371.0223
Block Reward: 25
How high is my share by PPS?
Re: How high is my share by PPS?
If you were solo mining when you found that block you get the whole reward all to yourself.
If you were a part of the pool (not solo mining) then the reward was split by everyone else on the pool at the time on that coin and you got .01 cents from it.
