Block Found
Block Found
Hi guys, what happens when I find a block?
Thanks
Thanks
OdysseyMining
Re: Block Found
what is your password setting?
Re: Block Found
if youre solo mining, you get the block reward, in youre pool mining, the block reward is distributed to pooled miners, this is the default as its most profitable for average miner
Re: Block Found
As stated above - Pool mining is pure socialism.
Your reward block is shared with everyone else. And their block reward is shared with you.
If you want to keep your blocks, you need to solo mine. Solo mine is "eat what you kill" - and only works if you have lots of hashing power.
Unless you specifically state that you want to solo mine - the system defaults to pool mining.
Re: Block Found
Thank you for reply, i like to share. it's only for info i am new
Re: Block Found
As a new user who likes info, may I suggest the readings of:
https://prohashing.com/help.html
It makes for a good read.
