help configure the newcomer DR100-pro
IngridKolt
Good day! I'm stupid in the mining
do not scold and help configure the newcomer DR100-pro. What to write in the "Pool1 Worker" field in other fields to make it work, until I try differently for nothing ![Image]()
Re: help configure the newcomer DR100-pro
Pool: prohashing.com:3333
Worker: [Prohashing Username]
Password: a=x11 d=[desired worker diff]
take a read through the help section on the main site for more password arguments you can use.
Hi
i have dr100 pro Pinidea
prohashing.com:3333
worker: ilkin
password: a=x11
i can not connect
can you help me
prohashing.com:3333
worker: ilkin
password: a=x11
i can not connect
can you help me
Set a 2nd pool as a backup pool, it may take a minute or two before it can see and connect into prohashing. Sometimes it needs another pool to go to initially before it can see prohashing and connect here to work. Just put in a 2nd pool and then try that.
When you say you cannot connect, on the miner page when you login it says it isn't connected, or when you log into the prohashing.com web page it says no miners on the earnings page?
