Hello,
During the weekend, today included, the percentage of rejected has been increased. Both stale and out of time. New orders in nicehash take a long time to activate. In my opinion in the pool seems to have a problem of overload that last week did not have.
Regards, thanks for the work.
High percentage of rejected
Re: High percentage of rejected
Unfortunately, I don't see a significant increase in CPU usage.
However, there has been a significant rise in the number of complaints from people who use Nicehash. These complaints appear to be solely limited to Nicehash miners, and are not affecting direct miners. I've asked customers who are encountering the problems to try connecting with a local miner, and the answer so far has always been that Nicehash is the only service affected.
Unfortunately, we aren't associated with Nicehash and don't have access to their network, so we can't troubleshoot this issue ourselves. I recommend contacting Nicehash's support and working with them, and perhaps they can investigate the problem.
Some users as the same problem with local miners, this must be a network issue
Hello,
thanks Steve, Nicehash increases the minimum difficulty to the maximum that can be assigned in parameter d of the password. I will try with higher difficulties and comment.
