Best settings for more coins
jirik
Post by jirik » Sat Oct 14, 2017 4:32 am
Hello,
can you please help me to make best settings when I want mining one of three selected coind with best profit.
For example I want mining Litecoin or GameCoin or Verge and mining one of them which have best profit at this time.
My settings will looks like: "c=Litecoin c=GameCoin c=Verge"
Am I need add more parameters to select best profit coin or it will be selected automatically?
Have order of coins in line some preferity or not?
Thank you in advance for you help.
L3AntyL3
Re: Best settings for more coins
Post by L3AntyL3 » Sat Oct 14, 2017 4:40 am
Correct me if im wrong but i dont think you can have three c= arguments in one line. You will have to change it if you want to mine another coin. Alternatively, leave the c= out completely and the site will choose the best one for you
jirik
Post by jirik » Sat Oct 14, 2017 4:43 am
You are probably correct, so how can I choose for example 3 coins to mining. Is there some option how to use parameter c= for multicoins?
Something like"c=Litecoin GameCoin Verge" or "c=Litecoin,GameCoin,Verge"?
Thank you.
lite em up
Post by lite em up » Sat Oct 14, 2017 4:56 am
go to settings and choose what coin or coins you want to be paid out in
jirik
Post by jirik » Sat Oct 14, 2017 5:02 am
I dont mean how select payout coin.
I want select which coin I want mining - if there is some option select manually three coins to mining and automatically select one with best profit.
Post by AppleMiner » Sat Oct 14, 2017 5:05 am
No.
You can either pick 1 static coin to pool mine or solo mine.
Or you pick the auto switcher pool.
jirik
Post by jirik » Sat Oct 14, 2017 5:07 am
AppleMiner > So its not possible. Ok, thank you for information.
lite em up
Post by lite em up » Sat Oct 14, 2017 5:10 am
i think it is any of the most profitable, or solo, mining One coin only
