Electricity cost
Maciej
Electricity cost
Post by Maciej » Fri Oct 13, 2017 7:44 am
I'm trying to configure my Antminer to send the electricity cost in the password field to Prohashing, so in the password field I entered:
p=0.16 w=800
Is that the correct syntax?
Regards
Aura89
Re: Electricity cost
Post by Aura89 » Fri Oct 13, 2017 7:48 am
That would be correct, but be aware electricty graph really doesn't work. Hopefully at some point it will, but it'll tell you that you're spending pennies a day rather then dollars.
Maciej
Post by Maciej » Fri Oct 13, 2017 7:52 am
Yes, I saw that according to the graph I sent $0.01 mining for 6 hours. That's why I got confused that maybe the syntax wasn't correct.
Thanks for clearing that up :)
xichas
Post by xichas » Fri Oct 13, 2017 9:45 am
Maciej wrote:Yes, I saw that according to the graph I sent $0.01 mining for 6 hours. That's why I got confused that maybe the syntax wasn't correct.
Hi
Despite of this change on the way to calculate electricity cost that was transferred to password arguments a known bug still was not corrected. The bug is that watts are miscalculated you need to put ten times more the wattage to give you the correct values. Lets take a L3+ as an example the real wattage is 800W but in the password value you must multiply that by ten to give you the correct electric consumption so it stays w=8000 and not w=800.
Regards xichas
