Miner Electricity Usage Setting
Tofugitive
Post by Tofugitive » Wed Oct 04, 2017 12:51 am
Brand new to ASIC mining and prohashing. Just getting set up and we're a little stumped on whether 'Miner Electricity Usage' is referring to the total wattage of all miners or the average wattage of one miner or other. Any clarification would be greatly appreciated. Thanks!
Re: Miner Electricity Usage Setting
Post by GregoryGHarding » Wed Oct 04, 2017 1:01 am
doesn't matter, the math is wrong anyway, its low priority on the list to fix atm so its not a working feature.
Tofugitive
Post by Tofugitive » Wed Oct 04, 2017 1:06 am
Ok thanks for the blunt answer! I'll disregard these numbers.
xichas
Post by xichas » Wed Oct 04, 2017 7:34 am
Hi i think it refers to the total wattage, but be aware that that feature its not working properly, bu if you want to have some close numbers on electric usage calculate the total wattage of your miners and multiply that total by 10 and put the result in the total wattage, and it will be close to your real electricity cost... regards
