How to adjust fan % on L3+?
I was wondering how to adjust the fan % on the L3+ so its not quite as noisy, I was reading how you can adjust the fan % to like 90 or 95% also the max degrees shutoff etc. How do I do this? Thanks!
Re: How to adjust fan % on L3+?
Miner General Configuration tab
check box adjust speed fan. 70% is about 4400 RPM 75 dcb
40% is about 3500 rpm 60 dcb
