" 1 error" message
- MaterialResources
" 1 error" message
I am receiving a "1 error" message on the earnings page is the area that tells me the hash rate of my miners. Only some of the minors have this message. The total count of miners working is correct at the top, and the efficiency is in the high 90s. It does make sense to me. Any ideas?
Re: " 1 error" message
You have miners that are using the same name. Some sites when you buy hashing power use the same name for each worker they send to the system.
To avoid issues they are each given a unique UUID to be tracked by, and just tosses an error that means....SOME MINERS HAVE DUPPED NAMES.
If you named the miners yourself, you can fix that for next time or now, if its from a pool you bought service from, you cant change it, and its fine as is.
- MaterialResources
Ok, I think I understand that. This is on Prohashing, and they do have the same name but different passwords. So I guess I am receiving credit. This "1 error" message just appeared yesterday for the first time. I have been working on Prohashing for about a week now. Thanks for your reply.
They just added it in the past few days so its new still.
On the password fields do you have n=worker1
and then on the next miner as part of its password n=worker2 so on and so on?
if you assign workers names using the n=workername password aug that may fix your errors.
That error is to fix issues with buying serviced hashpower from places to use to mine on the pool and issues with dupped worker names.
If you have your own miners you shuold be able to fix it by added n= to the miners passwords.
Hope that helps some.
- MaterialResources
I have similar to that, I just don't have the worker name in the password. I have n="something different"1 ....n="something different"5. I think that is the same thing as you have suggested. Right?
If you actually have " " marks on the password line, remove the ".
That may be what is triggering the error.
if its n="miner"1 that may be wrong.
n=miner1
no quotes.
just checking if you put the quotes in the password line or not.
n=miner1
no quotes.
- MaterialResources
Thanks a lot for for your reply, they have been very helpful.
- MaterialResources
Well, the1 error message is still there. Perhaps a demonstration of a hypothetical account would work.
If you can do this I am sure it will help. Thank you.
Hypothetical Account Name: cryptotree
Pool 1
URL
Worker
Password
Pool 2
URL
Worker
Password
Pool 3
URL
Worker
Password
Pool 1
URL
Worker
Password
Pool 2
URL
Worker
Password
Pool 3
URL
Worker
Password
I have the same problem now.
My password string is:
n=Antminer_L3_01
n=Antminer_L3_02
and so on.
Since yesterday I have the problem now that for some of my miners the name is not being recognized anymore. They just show up as a random hash string plus the (1 error) message.This only happens for some of my miners (currently 2), the rest is ok. Everything was working error-free for more than two months before.
What is the problem here? Please advise, thank you.
Best regards
poppy01
n=Antminer_L3_01
n=Antminer_L3_02
and so on.
Best regards
poppy01
