When inputting the password argument into my L3+ password field, I always get a random string as the worker name in the Earnings page.
I have ensured that I only input numbers, letters and underscore.
My argument looks like this: "n=worker_1" and I have input it into the field with and without the quotes. I have only ever seen the random string.
I have also rebooted the miner with no luck.
Please help??
Password n argument not working on L3+
Re: Password n argument not working on L3+
Do difficulty strings take effect if you try them? d=131072 <-- for examplebriggsr wrote:Hi,
Please help??
Try "n=worker1"
Feedback:
After adding the static difficulty the worker name showed up.
After that I removed the static difficulty and changed to the names I had previously and the worker name changed every time to what I had set it.
It seems the static request kick started it.
Thanks for the help.
