High delta on nicehash
asodoco
Post by asodoco » Sun Aug 27, 2017 6:39 am
i have 5-15% or more of delta on nicehash with g=off, h=1000 with scrypt, how can reduce the delta? thanks
S3KshuN8
Re: High delta on nicehash
Post by S3KshuN8 » Sun Aug 27, 2017 6:40 am
This is Prohashing, NOT NiceHash. Go ask for help there, please.
asodoco
Post by asodoco » Sun Aug 27, 2017 6:53 am
I buy from nicehash for mining here, anyway ok thanks
megaquake
Post by megaquake » Sun Aug 27, 2017 9:33 am
asodoco wrote:i have 5-15% or more of delta on nicehash with g=off, h=1000 with scrypt, how can reduce the delta? thanks
I would wait till after the update right now pool efficiency is not good
asodoco
Post by asodoco » Sun Aug 27, 2017 9:46 am
ok thanks
