- Chris will switchover the network changes later tonight.
- At the same time, I'm preparing a new release that will better handle WAMP disconnects, in the event they still occur, so that share insertion is more accurate and there are fewer losses. He will release it tonight too.
- Chris will correct balances due to lost shares tomorrow.
- Profitability will be lower today due to increases in difficulty overall with more miners turning on.
Quick update
Quick update
Here's a quick update:
Re: Quick update
Will the system credit us for mined coins while the site is down or is everything shut down until tonight. Im currently still mining here.
Re: Quick update
you won't get credit for lost mining opportunity, use a backup pool. you will get credit if you lost shares
Re: Quick update
10-4 thanks for tip
Re: Quick update
Chris successfully deployed the network connectivity fixes. Since he did, I haven't encountered any disconnects or delays.
Next, we'll be deploying the changes to more evenly distribute WAMP data so that there is less overload. That will require another 10 minutes of downtime within the next hour.
Re: Quick update
Really looking forward to that WAMP improvement, good luck.
Re: Quick update
Still waiting, because my L3+ have a lot disconnect (
Re: Quick update
Thanks for sharing an update.
Re: Quick update
3 weeks old...getting into the newer messages.
