I have 3 antminers L3+ mining on your pool. With a payout on Litecoin.
It has been working well for a few day.
But, during the last 15 hours, i never stop to be disconnected and sent to my second pool choice which is litecoinpool.
I never get rejected by litecoinpool. Do you have some ideas ? Do you have some stability problems ?
Regards,
Laurent
Never stop disconnecting and going to 2nd pool
Re: Never stop disconnecting and going to 2nd pool
i get "no valid shares yet" message. Then connect to second pool choice.
In errors, i get "Both primary and merge mined shares are stale" errors.
And i get almost no payout during the last 5 hours.
Is it due to your mining server that would be overloaded ?
I'm not sure what is occurring with the payout problems. I suggest submitting a support ticket about that.
As to the disconnecting issues, Javapipe is encountering routing issues. Chris is addressing the issues and expects to migrate the DDoS protection server to a new datacenter tomorrow, which should improve the connectivity problems.
lite em up
I have had same issue, seem to be always resetting and showing no valid shares yet , even without switching to 2nd pool, but logged in to status ant L3+ and was sure i seen it trying to mine 1st and 2nd pool at same time , like it was switching back and forth. Antminer does not reset just connection to PH site i think.
I am also facing this disconnection issue. How can we get update from Chris when he fixes this?
