Prohashing mining batch file for DASH
ruptan
Post by ruptan » Fri Aug 25, 2017 10:08 am
HI,
I am new...Please help..will this work if I only want to mine DASH coin? Also how can I make it to pay only DASH instead of bitcoin by default.
sgminer.exe -k darkcoin-mod -o stratum+tcp://prohashing.com:3333 -u xxxx -p "a=x11 c=DASH" -I 14 --thread-concurrency 8192 -g 2 -w 64 --auto-fan --temp-cutoff 85 --temp-overheat 80 --temp-target 70
Thanks
Re: Prohashing mining batch file for DASH
Post by GregoryGHarding » Fri Aug 25, 2017 5:27 pm
you have to set the pool to earn dash only by adding it and setting it to 100% payout in your settings
ruptan
Post by ruptan » Sun Aug 27, 2017 8:53 pm
But I want to make sure first the script is right. Is that right?
micca410evo
Post by micca410evo » Sun Aug 27, 2017 10:19 pm
Yes that is right. But you don't have to mine for Dash, you only want payouts in dash right? You could only set x11
ruptan
Post by ruptan » Mon Aug 28, 2017 1:28 am
Actually I want to mine for DASH only too.
micca410evo
Post by micca410evo » Mon Aug 28, 2017 2:40 am
c: sets a static coin to mine to support that coin's network. When this argument is included, the miner will only mine the requested coin, and will not switch coins when the rest of the pool is directed to switch coins. To mine CHNcoins only, for example, use "c=chncoin." This argument is case-insensitive. The selected coin must be spelled exactly as those in the list of available coins on the "charts" page, and the coin must be listed as "running." If the mined coin is placed into an error state (for example, if the coin forks and mining temporarily stops), then the pool will disconnect the miner rather than assign it to a new coin. This behavior allows powerful ASICs to specify a backup pool for when their preferred coin is not available. When used in conjunction with the d= (static difficulty) argument, the coin's difficulty overrides the static miner difficulty when the coin's blocks are easier than the static miner difficulty.
my sgminer and darkcoin-mod knowledge are insufficient, but looks like a good startline, you could set an extra (n={workername}) in your pw field. I don't know about the stuff after your PW arguments, (but this is more of a miner/local problem you should sort out)
Did you work out the payment settings already?
ruptan
Post by ruptan » Mon Aug 28, 2017 9:56 pm
yes. I did. Thanks
iamdavidpeter
Post by iamdavidpeter » Fri Mar 16, 2018 3:29 am
Cryptocurrency price prediction is just the start: a view into how crypto will change the world. Dash Vs Zcash Comparison and Price Prediction 2018.
