M.A.T. / Alcheminer disconnect
Hey Fellas,
Could one of you see why my worker "mat30" is kicking out after connecting?
I can't monitor on this side, but it seems to connect to any pool (litecoinpool/PH) but disconnects after a couple of secs. I tried vardiff, static, doesn't care, it connects shows up and disconnects after 10/30 secs. (Can you guys see the reason why on your side?) Thanks in advance.
Re: M.A.T. / Alcheminer disconnect
i have the same problem(micca410evo wrote:Hey Fellas,
have you tried just a single coin? like c=Bitconnectcoin
solved.. have added 4 more ttyUSB commands and that solved the problem.. (thanks for the 3 day headache M.A.T. )
What command? Write here please, because my problem does't fixmicca410evo wrote:solved.. have added 4 more ttyUSB commands and that solved the problem.. (thanks for the 3 day headache M.A.T. )
whitenoise wrote:What command? Write here please, because my problem does't fixmicca410evo wrote:solved.. have added 4 more ttyUSB commands and that solved the problem.. (thanks for the 3 day headache M.A.T. )
Do you have Alcheminers / M.A.T. 's also?
I'll post the lines i added tonight. Also set static at 32768..
Have you flashed your boards? Use you bfgminer or the crap stock python miner-software?whitenoise wrote: What command? Write here please, because my problem does't fix
If you looking so -> , than please take an moment and looking in my thread viewtopic.php?f=6&t=1003&p=4375#p4375
But since any months the support for ubuntu 12.04 (this OS is on the controller of MAT/Alche) ends ... so you need to search for alternative mirrors for pakets or downloading and installing manualy.
