Missing Shares
glccom
Missing Shares
Post by glccom » Fri Aug 18, 2017 9:33 am
It seems to me that shares seem to miss a lot right at the beginning of a coin switch, sorta like going up a hill, once you're at the top everything is fine, and if you stick on a coin for a long amount of time, it seems like the shares match. Not sure if this would be possible, but it would be great if we could get a breakout of shares (valid rejected etc) per working n= then we could compare daily shares with your daily shares, and we could put this issue completely to bed, if I match what you match then everything is good.
Just a thought. Similar to something like this:
https://www.litecoinpool.org/stats
Broken out over a 24 hour period would be perfect.
or any other ideas?
Thanks Guys!
--John
