Antminer L3+ connection problem
nimbus
Post by nimbus » Mon Aug 14, 2017 1:25 pm
Hello guys
I hope you are well . my problem is that i have connection problem with PH . I have 5 L3+ i tried everything but i couldnt connect my miners to PH
my settings were
URL :prohashing.com:3333 or stratum+tcp://prohashing.com:3333 or stratum+tcp://proxy.prohashing.com:443 i tried all of them
Worker: nimbus_1 nimbus_2 nimbus_3 nimbus_4 nimbus_5
Password: blank or static diff. (d=....)
none of them connected to PH and on miner interface the pool status were DEAD ! at all of them
i deleted pool info 2 and 3 left blank and it still didnt connect
any advice ???
thanks
Jalapan
Re: Antminer L3+ connection problem
Post by Jalapan » Mon Aug 14, 2017 1:29 pm
Does nicehash or litecoinpool.org work?
Maxumark
Post by Maxumark » Mon Aug 14, 2017 1:33 pm
URL : prohashing.com:3333/xnsub
Worker: nimbus
Password: n=1
example for worker 1 above.
for worker 2 use:
all the same above except:
Password: n=2
etc for each miner
Damito
Post by Damito » Mon Aug 14, 2017 1:36 pm
If your username on prohashing is 'nimbus' your worker name should be 'nimbus' without underscores etc. A worker name that doesn't match any username in prohashing will be rejected hence dead status.
You can name your workers using password argument n=[namehere]; for example this is a config that will work for nimbus_1 L3+:
URL: prohashing.com:3333
worker: nimbus
password: n=nimbus_1 d=131072
nimbus
Post by nimbus » Mon Aug 14, 2017 1:48 pm
thanks guys Ill try right now
nimbus
Post by nimbus » Mon Aug 14, 2017 1:52 pm
oh thank you very much guys it finally worked thank you so much !!!!
nimbus
Post by nimbus » Mon Aug 14, 2017 2:06 pm
guys i have another problem i just add one miner but when i try add more the pool status look dead
how can i add more miner
thanks
Maxumark
Post by Maxumark » Mon Aug 14, 2017 2:09 pm
Worker: nimbus
Password: n=1
Worker: nimbus
Password: n=2
Worker: nimbus
Password: n=3
Worker: nimbus
Password: n=4
Worker: nimbus
Password: n=5
nimbus
Post by nimbus » Mon Aug 14, 2017 2:41 pm
thanks Maxumark
hqm909
Post by hqm909 » Thu Aug 17, 2017 3:03 am
I'm the same with you. Can you access it now?
