Advice on Fan settings for Temp control
BitterCondition
Post by BitterCondition » Thu Aug 10, 2017 6:40 pm
Would these Highlighted readings be normal or should I manually set fan speed higher to lower temp
Chain# ASIC# Frequency MH/S(RT) HW Temp(PCB) Temp(Chip) ASIC status
1
72
384
120.95
0
I:0 O:49 Temp PCB
I:0 O:57 Temp Chip
oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo
2
72
384
121.20
0
I:0 O:47 Temp PCB
I:0 O:52 Temp Chip
3
72
384
120.89
0
I:0 O:46 Temp PCB
I:0 O:51 Temp Chip
4
72
384
121.25
0
I:0 O:45 Temp PCB
I:0 O:51 Temp Chip
vinylwasp
Re: Advice on Fan settings for Temp control
Post by vinylwasp » Thu Aug 10, 2017 8:52 pm
If noise isn't an issue I'd run them as cool as you can.
BitterCondition
Post by BitterCondition » Thu Aug 10, 2017 9:58 pm
Ty info.... I set the custom percentage on the miner to 72%.....it got a heck of a lot louder but overall lowered the temp settings on the PCD's and Chips by 4 degrees on each one...should I go higher than 72% and will it burn out the fans running that hard?
Edit forgot to mention that this raised the fan 1 r/min to 4100 almost a 25% increase and fan 2 r/min to 3276 almost a 33% increase from straight out of the box, setup auto-config and run.......
Splinter
Post by Splinter » Thu Aug 10, 2017 10:44 pm
What miner is that? For L3+ if temps are below 78°C/172°F its fine... in fact below 80°C its ok
BitterCondition
Post by BitterCondition » Thu Aug 10, 2017 10:56 pm
Splinter wrote:What miner is that? For L3+ if temps are below 78°C/172°F its fine... in fact below 80°C its ok
It is an L3+.... I only have one.........
so it would be alright then to reset back to factory default which was blank .... there is a checkbox for automatic shutdown at 80 degrees which is factory checked default.......
vinylwasp
Post by vinylwasp » Fri Aug 11, 2017 5:49 pm
Given the history of hashcard failures across S7, S9, R1 and L3 Bitmain miners, I wouldn't be relying on that thermal protection failsafe myself.
You have to remember that's there's likely to be a single temp sensor per card, leaving lots of room for a localized heat spike above 80°C which damages the card. I'd be trying to stay under 65°C myself.
BitterCondition
Post by BitterCondition » Fri Aug 11, 2017 7:57 pm
vinylwasp wrote:Given the history of hashcard failures across S7, S9, R1 and L3 Bitmain miners, I wouldn't be relying on that thermal protection failsafe myself.
Ty very much for info... I kept the fan speed custom set to 72%....it is loud but manageable ... the highest temp recorded on the chips is 54 degrees much lower than the 62 is was hitting continously on board 1.... also all PCB board temps are mid 40's now... I may increase the temp setting a few more degrees given your last post... TY very much ..your info very much appreciated......
