Gridseed mini USB 5 Chip Asic
astralhead
Post by astralhead » Thu Aug 10, 2017 3:02 pm
Hi Prohashing Team,
i have connected my Gridseed Asic miner to prohashing and receive Shares.
I kept waiting for 45 minutes but cant submit shares cause difficulty is always 16k or 8k and never went less.
as my miner only is 333kh/s i would think a difficulty about 64 to 512 might work.
in an old support thread i found minimum d=512 has to be set.
i also tried d=1024
i start hashing and get 16k.
any ideas what i can do?
i am starting with "-d1024 n=gridseed" and my workername is always visible.
so i guess my password arguments get submitted.
Thanks for help!
Greetings - Astralhead
gekkeleo
Re: Gridseed mini USB 5 Chip Asic
Post by gekkeleo » Thu Aug 10, 2017 4:33 pm
the lowest diff at the moment is 2048
astralhead
Post by astralhead » Thu Aug 10, 2017 4:45 pm
this should be visible in the faq :) i'll try! thank you very much!
Connected with 2048 - i am happy (although i dont think i can find much with that diff) :)
Post by GregoryGHarding » Thu Aug 10, 2017 6:15 pm
if youre patient, with vardiff it will eventually find shares and drop to the best diff for the orbs
astralhead
Post by astralhead » Fri Aug 11, 2017 4:57 am
GregoryGHarding wrote:if youre patient, with vardiff it will eventually find shares and drop to the best diff for the orbs
hi,
i had it running for about 1 hour and it found about 2 shares within this time.
once it went down to 8k
and restarted few minutes later at 16k again.
the fixed 2k works but is still to high for a constant amount of shares.
my miner is just to slow :)
nothing to blame at prohashing.
Thanks for your help!
