Hello all,
I have my miner set to a static difficulty of 131,072. I keep getting an error saying I am submitting shares to frequently and has changed the difficulty of my miner. The first change was to 262,144 and the second change was to 524,288. I am not changing these settings or are there still bugs being worked out that I can just ignore this error?
Thank you kindly,
Fernando
Miner submitting shares too frequently
Re: Miner submitting shares too frequently
whats happening is your miner is submitting more shares than ph wants in a set period of time, so it switches to vardiff and ignores your static setting
So is this best left alone? What do you suggest I do?GregoryGHarding wrote:whats happening is your miner is submitting more shares than ph wants in a set period of time, so it switches to vardiff and ignores your static setting
Thank you,
Fernando
there's not much you can do currently until the restraints on difficulty are relaxed. keep on doing what youre doing unless vardiff gets too high it messes with your rig, maybe try setting a higher static diff.
