nicehash + prohashing not profitable
buy power scrypt at a price of 0.332 50ghs on nicehash ,prohashing the price was for the whole order 0.384-0.480,..+25% should be + positive Delta 3.5% = 28.5%.... -the Commission nicehash -4%, -Commission prohashing-5%, the result - must earn +19% in total earned minus(-) -20%!!!. (the blocks were 1-10 sec. the delay was not)
Re: nicehash + prohashing not profitable
Dude the stats have been stuck for over an hour. The stats data is invalid right now.
It will be closer to 0.000029xx
**deep breath*** , clicks sketchy linkser649 wrote:https://yadi.sk/i/2SSHuj973LnhWS
Not sure what you are showing?
then when you believe the statistics? I waited all day that there was a delay between the blocks 1-10 sec!AvPro wrote:Dude the stats have been stuck for over an hour. The stats data is invalid right now.
Иди ты нахуй умник ебаныйAvPro wrote:**deep breath*** , clicks sketchy linkser649 wrote:https://yadi.sk/i/2SSHuj973LnhWS:p .
Thank you.
How long was your order and how recently? I'm saying the "live profit" has been stuck at the same value for well over 1 hour.
https://yadi.sk/i/ayT_3szx3LnjFzAvPro wrote:Thank you.
During those 20mins I believe the profit number on the website was not correct. Maybe lower than 0.332
I was thinking that since the profitability is changing a lot then I need to adjust the price I pay and/or the limit on nicehash a lot so that it is only mining when it is profitable. So need to write code that will get profitable data real time from prohashing, real time price and miners data from nichhash then update order real time using some clever decision code. Could this work to make a profit after prohashing systems are fixed?
