Automatic payouts
Automatic payouts
Been using this pool for a week now, much appreciating the nice proft ratios.
Altough i noticed that somedays the automatic payouts is not initiated.
Today LTC and Einsteinium did not pay out, but is over set threshold.
I request that you put a manual payout button once threshold is exceded.
Not being able to control when you can cash out is mildly annoying.
If only the automatic one did not fail, i'd have no complaints.
Keep up the good job, best pool.
Re: Automatic payouts
the automatic payout did not fail.
it just wasn't executed yet. As far as i understand the system is that sometimes the funds from the exchanges take longer to execute/arrive/whatever.
So some coins get a delayed payout.
Thx for answering, i guess that could be one explanation.. I'll just keep an eye on it and fingers crossed it pays out soon then or tomorrow.
While im at it i might add that i see most of the time in the pool my miners are calculating hashpower or not enough valid shares yet
"Both primary and merge mined shares are stale: (60-120 count)".
Capacity even sometimes shows that 1 or two or more of my rigs are not currently hashing, altough checking L3+ own ui, all my machines are hashing an average over 500MH in 24h and has not restarted for 12-24 hours, still pool shows all kind of disruptions in hashing, while my machines show no changes or drops in hashing. Pool also states my efficiency 96% average over 24h.
Edit: Payout recieved now.
Is it better to solo mine with L3+? Let's say, if you have 30 of themmycide wrote:Thx for answering, i guess that could be one explanation.. I'll just keep an eye on it and fingers crossed it pays out soon then or tomorrow.
so thats around ~15gh/s, some pools like give-me-coins and others have a pool hashrate of ~27gh/ssupershui wrote:Is it better to solo mine with L3+? Let's say, if you have 30 of themmycide wrote:Thx for answering, i guess that could be one explanation.. I'll just keep an eye on it and fingers crossed it pays out soon then or tomorrow.
youd be on par with them for how often youd find a ltc block. it you look over thier stats for block finding.. yours will be a little lower
Thank you so much for your reply!GregoryGHarding wrote:so thats around ~15gh/s, some pools like give-me-coins and others have a pool hashrate of ~27gh/ssupershui wrote:Is it better to solo mine with L3+? Let's say, if you have 30 of themmycide wrote:Thx for answering, i guess that could be one explanation.. I'll just keep an eye on it and fingers crossed it pays out soon then or tomorrow.
Their pool hash rate currently: 36.84 GH/s
Blocks solved by Pool (last 7 days): 14
LTC per block: 25
So having 30 miners is like working at 40% of their capacity, which will bring about 14(Blocks) * 0.4(Percent) * 25(LTC/block) = 140 LTC/week.
Is this correct?
I am kind of a beginner at this larger scale mining.
your math is correct, however there is a luck component to finding blocks aswell, not a value that can be calculated. you may do spot on your math, you might do horrible.. you might to great, or soso... luck can be a bitch but with that factor removed, it seems you've got the math figured out, keep in mind, any shares you solve while solo mining aren't rewarded to you, you depend solely on finding blocks for your profit.supershui wrote:Thank you so much for your reply!GregoryGHarding wrote:so thats around ~15gh/s, some pools like give-me-coins and others have a pool hashrate of ~27gh/ssupershui wrote:
LTC per block: 25
Is this correct?
Okay, I see. Thank you again.GregoryGHarding wrote:your math is correct, however there is a luck component to finding blocks aswell, not a value that can be calculated. you may do spot on your math, you might do horrible.. you might to great, or soso... luck can be a bitch but with that factor removed, it seems you've got the math figured out, keep in mind, any shares you solve while solo mining aren't rewarded to you, you depend solely on finding blocks for your profit.supershui wrote:Thank you so much for your reply!GregoryGHarding wrote:
LTC per block: 25
Is this correct?
If you can share any information about any pools for Dash mining to which I can compare my future hashrate of 750GH/s (50 D3 miners), I will really appreciate that
GMC also does x11, and multipool.us aswellsupershui wrote:Okay, I see. Thank you again.GregoryGHarding wrote:your math is correct, however there is a luck component to finding blocks aswell, not a value that can be calculated. you may do spot on your math, you might do horrible.. you might to great, or soso... luck can be a bitch but with that factor removed, it seems you've got the math figured out, keep in mind, any shares you solve while solo mining aren't rewarded to you, you depend solely on finding blocks for your profit.supershui wrote:
LTC per block: 25
Is this correct?
If you can share any information about any pools for Dash mining to which I can compare my future hashrate of 750GH/s (50 D3 miners), I will really appreciate thatAlso need to make a choice - to solo mine or not solo mine..
Thank you! GMC has only 2 workers mining this coin... volume too low.GregoryGHarding wrote:GMC also does x11, and multipool.us aswellsupershui wrote:Okay, I see. Thank you again.GregoryGHarding wrote: your math is correct, however there is a luck component to finding blocks aswell, not a value that can be calculated. you may do spot on your math, you might do horrible.. you might to great, or soso... luck can be a bitch but with that factor removed, it seems you've got the math figured out, keep in mind, any shares you solve while solo mining aren't rewarded to you, you depend solely on finding blocks for your profit.
multipool.us has 17,678.297 GH/s total... this is just about 13% higher than what single D3 miner would do. And there is going to be many more of them... so these 2 pools are too little when it comes to Dash mining...
By the way, if you have anything else to share, please do
